Results 1 to 11 of 11
Thread: Screen Minimum Clearance
08-10-2005, 05:19 PM #1
- Sep 2003
- Nashville
- 7
I want to put up a picket fence to screen the front and right sides of my Rheem 2.5 ton Mod # RRKA-A030JK08E gas/heating electic cooling package unit. What minimum clearances between the fence and unit should be used?
Thanks,
Fred
08-10-2005, 08:41 PM #2
- Mar 2005
- Louisiana
- 211
3 feet being it's only a fence
08-10-2005, 08:48 PM #3
All 3 exposed sides have service pannels. Give 'em room to work.
08-10-2005, 10:14 PM #4
you could probably go 8"-12" as long as fence was easily removed for service. remove it before service tech gets there.
08-12-2005, 04:55 AM #5
- Feb 2003
- Huntsville,AL
- 4,125
use the mfgr recommendations & be legal
allow someway for servicing, even removal of whole unit.
02-03-2006, 03:20 PM #6
- Sep 2003
- Nashville
- 7
Thanks for the pointers. Here's what I came up with...
Clearances on 3 sides are greater than that specified on the nameplate. For unit replacement fence panel at top of pic can be set to the side (by owner, yours truly) by removing 4 SS wing nuts. Space to enter (at bottom of pic) is 28 inch wide.
This beats tech having to cut thru shrubs with a machete I'm thinkin'.
Your thoughts????
02-03-2006, 03:23 PM #7
looks good from here.
02-04-2006, 12:45 PM #8
Beautiful job!
But wheres the cup holders and the work bench?
02-04-2006, 12:57 PM #9
- Sep 2003
- Nashville
- 7
Re. cup holders and the work bench...
I'll get right on that
02-04-2006, 01:02 PM #10Senior Tech Guest
Nice. I could learn to appreciate customers like you...good perspective on the photograph to, from roof?
02-04-2006, 01:29 PM #11
- Sep 2003
- Nashville
- 7
Photo was made from deck. My bride nixed the idea of a roof shoot.
