Results 1 to 13 of 15
05-09-2011, 02:34 PM #1
New Guest
- May 2011
- 3
Help! AC Problems Capacitor? Contactor?
Installed a new capacitor last week and the air would come on sparringly. The capacitor is different from the one that was bad, a plastic grey one with a lip that fits into the hole of the rheem unit. The new one is a protech 55/5-mf 370v. The new capacitor reads 55 mf and 4.7 mf when checked. I'm getting 242 volts to contactor when testing L1 and L3 and when I engage the starter bar T1 and T3 reads 242 volts, turning the fan and compressor on. I cleaned the contactor with contactor spray. What am I overlooking?
05-09-2011, 02:40 PM #2
Professional Member*
- Oct 2006
- The Beach
- 459
You need to call someone that knows what they are doing. Be careful-you can get hurt.
Blue Fox
05-09-2011, 02:48 PM #3
New Guest
- May 2011
- 3
The old capacitor and the new one are the same mf and volts. I discharged the capacitor and tested after removing the disconnect box switch.
05-09-2011, 03:00 PM #4
- May 2010
- 1,289
Could be several things. Control Board, Contactor, T-stat, etc. How do you know the previous capacitor was bad?
05-09-2011, 03:08 PM #5
New Guest
- May 2011
- 3
Zero T......
The Herm side read 51 mf when tested on the old dual capacitor. I also checked the T stat by doing a resistance test and it checked out.
05-09-2011, 03:11 PM #6
- May 2010
- 1,289
I would like to help you further, but unfortunately have to follow the rules of the forums. To receive further help please apply for pro membership and we will be glad to assist you.
05-09-2011, 03:16 PM #7
You may have a weak coil or pitted contacts. I would suggest calling a pro rather than keep throwing money at it. You may eventually fix it, but at what cost? If you're unfamiliar with the operation of the system, it's best left to the pros that know.
05-09-2011, 03:22 PM #8
05-09-2011, 10:38 PM #9
05-09-2011, 10:45 PM #10
05-11-2011, 08:48 AM #11
05-11-2011, 08:57 AM #12
I've made that same mistake and overpaid for one of those flux-capacitors. They do pack quite a punch though. 1.21 Gw! Jumped R to G and my unit disappeared! Lucky for me, it appeared one minute later and the clock on the ignition board was exactly one minute ahead of mine!
05-11-2011, 09:02 AM #13
Good to know weve got some comedians around here!!!!!!!!!!!
the site rules.
