Thread: Novar
    Michigan
    Novar
    Heya Fellas
    Having a problem with my novar system
    Have a Novar I-Scope software/front end with a ESS-32 edit.
    Anywho I have a RTS-30 (Novar) temp sensor going into a IOM/2 Module and it is displaying -40 deg supply sensor, I changed the sensor and it says -40 deg supply sensor, I reversed the wiring and it gives OFAULT!
    So could I have a problem with my IOM/2 Module/Board, anyone know why?
    Thanks Guys
    Brian
    The signal is 4-20mA
    Quote Originally Posted by durussel78 View Post
    Heya Fellas
    Thanks Guys
    Brian
    Try pulling the top section off and resetting
    Jan 2003
    Toss your meter on the current loop and see if it is what it should be.
