Thread: Ruud tonnage
    Jul 2005
    Any of you fellow techs know what tonnage i have with
    this Ruud air handler, model UHQA-0805 BLS? im used to
    24, 30, 48, 60, in model number, thank you.....
    Toledo, Ohio, United States
    2 ton i believe
    No Heat No Cool You need Action Fast
    Aug 2005
    Sounds like you have the wrong numbers if it's Ruud. Looked through an extensive cross over reference I have and didn't find it anywhere. Is it a straight fan coil AHU or does it have a heating section to? If you have it nearby recheck your numbers.....sorry!
    rheemote net.com
    Terry is right, the 08 was 2 ton. The 05 meant 5kw.
