    looking for a high pressure cutout with manual reset that screws on liguid line schreider fitting with a tee so I can still hook up refrigeration gauges.
    first company condensors do not come with low or high press sensors and the coil is a pain to cleen so I want to add cutout to save compressor between cleaning.
    Jul 2002
    Alpharetta, GA
    I am guessing ANY refrigeration supply house can get you the manual reset HP safety. The tee is a separate item also from the supply house. They'll likely have it at the counter. Screws onto schrader, depresses schrader, has two 1/4 ports with or w/o schrader for your needs.
    Central New York
    RANCO makes a wide variety of refrigeration controls. They should be available at any refrigeration / a/c supply house.
