Results 1 to 13 of 21
    Apr 2008
    Northeast
    Hmm Johnson FX20/60/70 Capacities + Integration
    Is there anyone who has extensive experience with these controllers? I was always curious to know how many controllers can be handled by each version of the FX Supervisory Controllers....although I'm sure the capacities are not based on controller count but more so on type of written programs as well as FX alarms, trends, etc. A majority of the field controllers will be controlling CW/HW/VFD-controlled AHUs and VAVs. One of the FX Supervisory Controllers will also be integrating to an existing Trane Summit System via BACnet IP (Chiller Plant, AHUs and VAVs) and possibly future Honeywell Spider Field Controllers via Lontalk.
    Thanks.
    Apr 2008
    Northeast
    Quote Originally Posted by NightrainATC View Post
    Thanks.
    By the way, the Johnson Field Controllers coming off of the FX Supervisory Controllers will be FEC BACnet Controllers.
    Thanks.
    Melbourne
    ....the Johnson Field Controllers coming off of the FX Supervisory Controllers will be FEC BACnet Controllers.
    Is this a real job ...or a thought experiment?
    How are you gonna program the FECs?
    1 + 1 = 3 ( *** for very large values of 1)
    Be brave. You cannot get eaten by an imaginary tiger.
    Apr 2008
    Northeast
    This is a real job. The FECs will be controlling AHUs, VAVs and Hot Water System equipment and will communicate to the FX Supervisory Controllers via BACnet MS/TP.
    I'm figuring it will be best to use FX Supervisory Controllers vs Johnson NAEs because I feel the future integration to existing 3rd party Honeywell LON Controllers will be much smoother using FX20/60/70 Controllers.
    Melbourne
    This is a real job.
    ...so, youre from a JCI branch ... or an ABCS?
    The FX will easily communicate to as many FEC as an NAE. What sort of unit load do FECs present on a MSTP bus? Same constraints for FX.
    we have FX60 that concurrently interfaces 5 different RS485 bus including modbus and Bacnet, SNMP, consumes RS232 strings from the fire system, and serves graphics for the site....and it still has capacity.
    How many devices do you need to communicate with
    Apr 2008
    Northeast
    We are an ABCS but currently have access to both FX & Metasys Lines. I'm looking at around 450-500 FEC field controllers (400 of which are FEC VMA VAV Controllers and the others for AHUs and Hot Water System equipment control). I'm thinking 2 or 3 FX Supervisory Controllers would be needed....not sure if to go FX60 or FX70s.
    Western Oregon
    Generally, it's the bus that limits the number of controllers under a Jace.
    RealEyes
    Realize
    RealLies!
    Apr 2008
    Northeast
    Quote Originally Posted by rad1 View Post
    Meaning what.....bus length or cable type? FYI...the bus cable will be 22awg, 3-conductor shielded for BACnet communication over the FC bus.
    Western Oregon
    Some busses allow a fixed max. number of devices. With a Jace tho you can add a second or third network and increase the device count that way, or adding a router to your network may allow an increased count on a bus. I don't think I've ever seen or heard of an "absolute" number of controllers that a Jace could handle. You've mentioned some of the features that could add to that limit though,
    i.e., "written programs as well as FX alarms, trends, etc."
    RealEyes
    Realize
    RealLies!
    Near Philly
    I've got a site with 3200 points on a single FX60. The N2 bus is split in halve, on two different physical ports. I have the server software package doing the graphics and trending. The FX60 is maxed out. I have similar sites with 2300-2400 points and everything runs at a much lower level. So, the consumption is defiantly not linear.
    Apr 2008
    Northeast
    Quote Originally Posted by mechdorn View Post
    Mechdorn,
    Thanks. This is the type of information I was looking for. I too will be implementing a FX Server so is it safe to use 1600 pts per trunk as a max guidline?
    At this time, we are used to using NAEs which have controller count limitations. Because this is a big facility which may require 4 to 5 FX Supervisory Controllers, I'm assuming we will use the RS-485 adapter for each FX Supervisory and run (2) BACnet MS/TP trunks per FX with repeaters as needed.....is this correct?
    Lastly, I will be bringing in existing Trane pts from (2) BCUs...approx a total of 600-800 pts...over BACnet IP into the FX Server. Also future Lontalk integration to approx (15) Honeywell Spider field controllers which would require a FX LON card.
    Near Philly
    I omitted the fact that all of these jobs that I'm referring to all have the extended memory license installed. With a FX60, 1600 points maybe a push without the extended memory, no problem with the extra memory and a supervisor software serving up the graphics.
    Apr 2008
    Northeast
    Thanks. I figured you had extended memory. I'm going with extra memory anyway to accommodate future controllers.
    Question: If I had a job without the FX server and it had (3) FX Supervisory Controllers, could the customer hit all three controllers on their network from under one controller or do they have to go into individual access points to see what's under each controller? Also with this scenario, is there anything I should no regarding the graphics?
    Thanks again!!!
