Results 14 to 26 of 40
    Quote Originally Posted by jjrr007 View Post
    * If you have a measurable amount of amps, you should have volts and that should give me some idea if the blower is getting power.
    * Yes, there is no positive volts in AC- I meant the black wire. (I had been working with DC often in my previous trade). It doesn't matter.
    * I have seen many situations where the blower is attached to the transformer. It is connected on the line side at the transformer and there may be a wire between.
    Might I make yet another suggestion...
    Say what you mean and mean what you say.
    Aug 2010
    JPSmith,
    Your point is well made. I am clear that my original post could have been more exact. The question itself is clear and all of the information needed to answer it was present:
    I wanted to use an ammeter to see if the blower is receiving volts. My thought is that if the blower is trying to start, I should receive a reading on my ammeter. How much of a reading would I get on a 1/3 (120 or 240 volts) blower reading if the blower was trying to start?
    I tried to clarify the other points of my post, but you keep on bringing up the flaws My hope was that this question would not only help me, but help others on this forum.
    In either case (I agree), I will be sure to spend the time and write exact questions. Also, I will apply for the Pro Membership and ask the questions there. Does that work?
    You can take my comments personally and get mad at me or you can take them to heart and grow as a technician from them.
    Your call.
    Southeastern Pa
    Don't take JP's advice (or mine) as mean or negative.
    A lot of guys come through here and need help in one way or another. Good communication is a hallmark of a good tech, and you will see that here.
    When you have Pro membership you can read the articles on electricity and troubleshooting. Two are mine. Electricity comes up a LOT here. So, we have many opportunities to learn.
    Once again, welcome. You will like the learning.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
    Jan 2001
    I have trouble verbally communicating.
    I can write very well..... but sometimes when talking I say the opposite of what I mean to say... its hard to explain.
    I think its where Im always thinking about stuff.....I let a lot eat at me and I worry about a lot of senseless things that dont matter......So I think.... that I dont spend enough time thinking about what I am going to say and end up letting stuff get out backwards.... A lot of my yes and no answers are correct....but in the way I am thinking about the situation......
    But it could be something completely different....some kind of quirk in the old noggin...... thinking faster than those around me......in a slightly different time.....another dimension.....but not completely......sort of halfway in.....or not quite half way in.......
    I think the original poster should try and clarify his question here....
    The bible is my constitution and the constitution is my bible.
    WE THE PEOPLE refers to THEM and not YOU.
    Chewbacca Mom 2016
    Southeastern Pa
    Quote Originally Posted by corny View Post
    Could be a condition known as "flight of ideas," and maybe some verbal dyslexia.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
    Aug 2010
    Thanks Timebuilder. You answered my question earlier. If the blower is locked (or not responding), then I would not measure amps. I forgot about this. Amps can be measured when testing under a load. So this won't work. It was beneficial to ask. Also, I will be more clear on my posts.
    May 2010
    Yes, if the rotor was locked you would experience LRA (locked rotor amps). The LRA of a typical motor is 5 to 8 times its FLA (full load amps)
    Aug 2010
    Interesting. ZeroTolerance. Other than a situation of the blower being over heated, do you think this an OK (would work) way to test if the blower is getting electricity?
    May 2010
    I wouldn't say it was the best test, as checking the voltage is ideal in this situation.
    Getting out your test leads and finding a good place to set your multimeter where you can read it is sometimes frustrating. I agree
    All Multimeters need magnetic backs so you can stick them to the unit you are working on
    Aug 2010
    I agree. It's not the best test. Sometimes, testing the voltage to the blower can involve testing the voltage in spots that are hard to get your leads in.
    Recently, I was testing voltage on a 240 volt blower in an attic. The electricty arced between my leads. The sound startled me; my latern light went through the ceiling tiles. If I can avoid this from happening in the future by using my ammeter for some situations like this, I prefer this test.
    May 2010
    Only way you will get an amperage reading is if the windings are open and grounded out, partially grounded out, or arcing windings on 3-phase motors and some single phase motors that are multitaps or use a capacitor. Typically, if the windings are completely grounded out you will throw a breaker. You can also typically tell if the motor is bad by the play and spin in the motor shaft.
    Aug 2010
    So far, the only situation I can think of that this wouldn't work is if the blower is over heated. What other situations can you think of (this technique would not work)? Would the amperage be measurable using one wrap around the ammeter? Thanks again.
