    I got a 1.5 ton unit to replace. Old unit has 3/16"ID liquid line, but new 10 SEER unit has 1/4" ID line size. Both units run R22. One of our techs say use the old 3/16" line size is OK, I'd rather change out the line to what the new condensing unit has (1/4"). Total run is small, maybe 20 feet with minimal bends. Suction line size is the same amoung both units, if it matters.
    Whacha think?
    I always replace the line set no matter what even with a line drier i would not be confident.
    What is old unit? Only thing I know of smaller than 1/4" was the old Lennox RFC system and you definitely need to get of that lineset.
    i'm guessing you haven't read the installation manual.
    try it, you will finds all kinds of info and required specs there.
