Results 1 to 13 of 24
Thread: Help please!!
    Aug 2005
    I have a Trane XL1200 that's 10 years old. The compresser is trying to kick on but is unsucessful. The fan is running but the unit isn't cooling. I'm no electrician, so I'm sort of ignorant to how it works. It sounds to me like it might be low of freon, but doesn't being low of freon mean I have a leak?
    Dec 2001
    Chicago, N/W burbs
    yes, you have a leak.
    R2B4BTU
    Aug 2005
    Thanks Otto,
    After 10 yrs. of no problems, what would cause a leak? And, how long does a compresser normaly last?
    Otto means fluid is leaking out of your brain.
    Shut the thing off and call someone, and go see your doctor for an MRI.
    Hey cockroach, don't bug me! ©
    Dec 2001
    Chicago, N/W burbs
    Those Trane compressors last a good long time. Could be a bad start capacitor, potential relay or burnt wire terminals. If you're not too sure then it may be time to call in a technician.
    Nothing really "causes" a leak, they just happen.
    R2B4BTU
    Colorado flatland native
    Also could be off on thermal.
    Either way, call the man Aunt Bee or be prepared to buy a new one after you "F" this one up.
    Walter Matthau
    I think he left, he is outside getting electrocuted as we speak. On the bright side, it might stop the brain leak.
    Aug 2005
    Called a Tech, he came out and replaced a capacitor and it's running like a top. $45.00, I'm in the wrong buisness.
    Houston,Tx.
    $45.00 at that price he won't be in business for very long, so no you are better to stay were your at than try and make it in this business selling capicators at $45.00, maybe some just live in their trucks with no overhead but food and gas.
    South Carolina
    45.00 for the part and labor? thats not right.
    Aug 2005
    I guess I forgot to mention that he is a good friend of mine. He told me what it would cost if I had to call someone else.
    Feb 2005
    Coffeepot, Ohio
    I was gonna say capacitor.
    If you can't push; pull... If you can't pull; GET OUT OF THE WAY!!
    Cincinnati
    No, I was gonna say it 1st. But I forgot how to spell it.
