Thread: Tran XE 900
    May 2011
    Tran XE 900
    I Have A Trane XE 900 Heat Pump. Model # TWD736B100AO. Serial # F16268116. What is the Seer and ton rating?. This unit was installed in 1991. How much longer would you expect it to run? I average about 1200 KWH per month in a 1800 Sq Ft home in Florida. Can you give me a calculation of energy usage versus higher Seer rating . Thanks
    Aug 2009
    Beatrice, NE
    The unit is a 3 ton, roughly in the 9 SEER range depending on inside unit. As far as what you can expect for energy savings, rule of thumb I use is 10% per SEER point. As far as acutal savings a load calc works best to figure it.
    Mar 2011
    Galveston Texas
    as far as how long it will last. depends on maintence, environment. I know here just environment alone that thing would have been a ball of rust long ago.
    Virginia
    at 21 yrs it crap out anytime, or could go another 20 yrs . you can save a few bucks a month on electricity if you replace it
