Page 1 of 4 1234 LastLast
Results 1 to 13 of 44
    Feb 2005
    Dothan, Al
    What determines the suction pressure in the refrigeration system ?? Where does the pressure come from ?
    Gone
    1. Heat load
    2. Super heated vapor
    Aug 2005
    LA
    born
    Vapor Determines The suction pressure.
    The amount of heat absorbed at the evap.
    Feb 2005
    Central Alabama
    the amount of heat absorbed by the refrigerant in the evaporator.
    And with the increase in refrigerant temperature the pressure will increase accordingly.
    May 2005
    the amount of heat absorbed in the evaperator (heat load)
    May 2005
    What do we get if we pass the test ?
    Feb 2005
    Central Alabama
    tomorrow off
    leland nc
    the super heated vapor determins the pressure
    the more heat absorbed the higher the presure the less the lower
    leland nc
    only if your not the guy on call
    Feb 2005
    Central Alabama
    this is true
    Jun 2001
    compressor capacity
    Feb 2005
    Dothan, Al
    Tinknocker, Hvacmarie are correct. The only thing that causes pressure is the 'vapor', expanding. More vapor = more pressure, less vapor = less pressure.
    Bama, Hvacguy, Beenthere: The heat absorbed is what causes the liquid to boil into vapor which then creates pressure.
    The compressor suction only allows the refrigerant to boil at a lower temp, but does not have anything to do with the amount of pressure produced.
    BB: The capacity of the compressor is only concerned with how much volume can be 'pumped'. Again, nothing to do with suction pressure. The capacity will change with the temp of the suction vapor, but not the pressure.
    Someone correct me on this one if I am wrong.
    Thanks all for yur replys,
    Richard
