    Spokane Wa
    Copeland 6D compressor oil plug
    Wanting to know if you can screw an angle valve into the oil plug hole for clean up oil changes on a 6D compressor. I heard you can drill and tap the original oil plug but was wondering if anyone has put an angle valve in these.
    East of big city prices.
    1/4" mpt
    May 2010
    griz, here is a little tip so you do not create a oil mess when you remove the 1/4 mpt plug.
    1. Put your gauges on service valves
    2. Front seat suction service valve push in contactor and pump down compressor cavity. Right before you go to zero open contactor.and front seat discharge service valve.
    3. hook up your vacumm pump and pull compressor cavity into a negative, have your angle valve ready with thread sealer,(Loctite 567 my choice)
    4 Remove oil drain plug, vac. pump running will keep oil in compressor so you can install angle valve...Hope this helps Good luck!!
    Spokane Wa
    Thanks, I am waiting on the new compressor to come in to replace the shorted to ground one. I will install the valve before it goes in. I guess I am a little surprised when you say 1/4 mpt since the plug is very large, like it takes maybe a 7/8" wrench to remove plug. I guess it has a small hole.
    Hampton Roads, Virginia
    Quote Originally Posted by griz View Post
    No you need an adapter
    Kevin
    "There is plenty of room at the top because very few people care to travel beyond the average route. And so most of us seem satisfied to remain within the confines of mediocrity." -- Benjamin Nnamdi Azikiwe, first president of Nigeria
    "It's not the customer's job to know what they want." -- Steve Jobs
    Dec 2010
    new jersey
    I think this would be better for draining the oil in the crankcase...It goes on the side of the comp. usually where the oil crankcase cap tube would go...and can be left on for future use.
    Henry makes it...it can be bought at United Refrig.
    keep in mind though you can always put a hose at the 1/4 flare connection at the pump...turn the comp. on and pump it out.(don't forget to close the oil line) you have aprox. 2 mins. before it fails on oil.
