Thread: coil cleaner
    Jan 2005
    Central NC
    Will non-acid coil cleaner damage coils if it is not completely rinsed off?
    Jan 2002
    Ft.Worth,Tx
    Coil-cleaner
    Any coil cleaner will damage aluminum coil if not rinsed.
    De-Tints and you loose capacity of heat transfer, according to what I have read.
    But, I have used green evaporator cleaner and not rinsed and usually ok. If it were me I would read what is on the bottle of cleaner and follow instructions.
    'Life begins with the journey each day'
    and yes , the coil must be removed to clean it properly
