Results 1 to 20 of 30
Thread: Amana vs. Trane
    May 2011
    Amana vs. Trane
    We are looking for a 2 ton heat pump replacement in the Washington, DC area (temperate climate). Have gotten prices for an Amana ASZ14 with an ASPF313 air handler rated at 15 SEER and 8.5 HSPF anid a Trane XL16I with a 4TEE3F31 air handler system rated at 16 SEER 8.5 HSPF.
    Price for both systems are similar so I need recommendations on which brand is better. Can any one out there help me? Thanks in advance.
    Fairfield county Connecticuit
    I like Trane but the installer is more important
    Jul 2009
    Damascus MD
    i like trane as well. we also serve the dc area. amana has a fail/replace whole unit warranty. which trane doesnt. but if installed PROPERLY the unit shouldnt fail in 10 years anyways. unless of course u dont change filters
    If a Trane 16i is similar in price to the Amana, I would worry about the Trane installation. And go with Amana.
    Jan 2002
    Ft.Worth,Tx
    Post
    Quote Originally Posted by jicaza74 View Post
    Trane is quality system, but larger equipment size, Amana equipment is good and smaller in size and has good warranty
    BUT, it's hard to stop a T R A N E !
    'Life begins with the journey each day'
    Mar 2006
    The South
    jicaza
    for the washington, dc area, I would not purchase a HP that did not have electronic demand defrost.
    For heating efficiency, that is not the best matching air handler for the two ton XL16i.
    In fact since this is only a two ton, I would look at Trane's sgl stg mdls XL15i and XR15 HP condensers.
    these are my minimum specs for a new HP system. both outside and inside units should be replaced to have a properly matched system.
    15 SEER, 12.5+ EER, 9 HSPF
    best matching VS air handler
    full BTUs in both cooling and heating for your rated size
    R-410a refrigerant(same as Puron)
    scroll compressor preferred
    electronic demand defrost preferred
    thermostat with "dehumidify on demand" feature
    staged backup heat strips
    new and correctly sized refrigerant lineset
    you want a thorough inspection of your ductwork system. size, overall condition, supply and return lines, insulation qualities, leak test, etc.
    any hot/cold spot issues in your home should be addressed.
    I would only use authorized dealers for the various brands that provide quotes. see mfg websites.
    I would look at Trane/AmStd,Rheem/Rudd,Carrier/Bryant.
    IMO
    Feb 2005
    cincinnati ohio
    Trane Vs Amana
    ....Beenthere has gone to the dark side .....
    My avatar is a picture of a Goodman Silencer .....These were commonly used in Goodman country ....Photos by hvac tech ( PaysonHVAC )
    Toledo, Ohio, United States
    Quote Originally Posted by bob hubbard View Post
    Twilly says you got that right....you can dress a goodman up but its still a goodman
    No Heat No Cool You need Action Fast
    Nov 2007
    Sherman, TX
    You can't assume anything based on the price. Get references. The Trane guy could just simply be hungry for work and/or have better controlled overhead.....and by that same token, the Amana dealer might be trying to score a week's wages off of one job.
    That being said, using the same multipliers, our American Standard systems generally wind up selling for around a grand per system higher than our Tappan systems, if you're looking to compare on pricing.
    Technical incompetence is NOT a sales tool....
    Does make ya wonder why a single stage Amana is priced like a 2 stage Choo Choo. Either Mr Amana is pricey or Mr Trane is cheap or doing less.
    It may be a dressed up Gooman but the Amana is still a nice unit. High & low pressure switches hooked up to a Copeland Comfort Alert module. 2 speed fan, sound deadening top. Not too bad compared to some.
    Twilly says To TigerDunes???? Who ain't an authorized goodman dealer?
    Didn't know there was such a thing as authorized Goodman dealer? Around here anyone with an EPA card can buy them although the biggest supplier of them has clamped down.
    Mar 2006
    The South
    not including any Goodman dealers...how many are there?...
  14. #14
    Here and there
    Install being equal I say Amana.
  15. #15
    LOL... A 2 stage Trane, at a price comparable to an Amana/Goodman single stage, some corners are being cut somewhere with the Trane install.
  16. #16
    Aug 2009
    NW FL
    You may want to look @ Whirlpool's Gold WGHP48 18,16 & 14 SEER series HP's, as their warr is comparable to Amana's w/ LFT replacement on the condensing unit and may be less $. It too is mfrd by Goodman.
    http://www.whirlpoolhvac.com/products/heat_pumps
  17. #17
    Nov 2008
    California
    Quote Originally Posted by RoseRx View Post
    Where did you get the info that this HP is manufactured by Goodman? There's nothing on the Goodman or Whirlpool sites to indicate that.
  18. #18
    Cincinnati, Oh
    Quote Originally Posted by HPGui View Post
    Because anyone thats remotely familure with goodman, can pick a goodman out of a lineup. Even if it's wearing a fake mustash.
    It's a goodman.
    "Just get it done son."
    Dad adjusted
  19. #19
    Cincinnati, Oh
    Quote Originally Posted by hvacvegas View Post
    It's a goodman.
    Oh yeah, and because they used the same pictures in their install manual, as with the goodman install manual. :-P
    Dad adjusted
  20. #20
    May 2011
    trane..........
    in my opinon the trane units are way more reliable compared to goodman or amana. i think trane is one of the best systems you can buy.
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
