Results 14 to 26 of 26
Thread: Fiberglass Ladders
08-06-2005, 03:35 PM #14
Banned
- Nov 2000
- Coastal Georgia
- 34,902
I know you hate to get rid of it. But do what I did, run over it with the van. When I bought a new one I also bout a aluminum one that went up 16 feet and I use that one more than the fiberglass one and it is a lot less weight .Originally posted by lusker
Since I am too vain to read a ladder website...
Anyone know how to keep an old yellow fiberglass ladder from sheading fiberglass into your body?
Any special treatments?
I have one that is around 13 years old... great ladder, but everytime your arm or leg bumps it you get fiberglass in you.
thanks
08-06-2005, 03:57 PM #15Yea , the sun will make it flow.Originally posted by condenseddave
LMFAO. And set it in the sun....Originally posted by NedFlanders
wrap it in duct tape
The you can peel the tape off and there will me a nice new "safety" coating on it.
I bet your tools will even stick to the sides then.
If we all put our heads together , we are a very powerful bunch.
08-06-2005, 04:49 PM #16
- Aug 2002
- 6,047
almost anything you coated it with would be non conductive. What constitutes conductivity is something which provides a path to ground, electrically.
anything applied with a paint brush or sprayed on would probably NOT conduct electricity.
Originally, the outer coating was fiberglass resin. Why not just buy some resin and re-apply it over the channels of your ladder?
08-06-2005, 05:15 PM #17
Banned
- Nov 2000
- Coastal Georgia
- 34,902
In use to worry about conductivity with ladders until I realized the several times a year I got hooked up and shocked good, I was not on a ladder. Then I thought about how many times I had done electrical work right off of a extension ladder an that came out to be a whopping zero times. That was when I bought a medium height lite weight aluminum extension ladder and I love it.
08-06-2005, 05:24 PM #18
James... our average guy, including me, is 210# + without tools. We have all red fiberglass now... it is just the yellow one that has been around so long. Darn good ladder still.
Maybe I can coat it again, but I really like the car wax idea.
08-06-2005, 05:39 PM #19
Banned
- Nov 2000
- Coastal Georgia
- 34,902
Get a 55 gallon drum of this and dip the ladderOriginally posted by lusker
08-06-2005, 05:45 PM #20Senior Tech Guest
http://www.tapplastics.com/shop/product.php?pid=30 - 39k
Try this link.
08-06-2005, 05:47 PM #21Originally posted by NedFlanders
Don't forget to use Armaflex glue or it will not work.
If common sense is so common how come so few of us have it!
08-07-2005, 11:08 AM #22
Go see the "paint guy" at your fav. auto parts dealer. Get some fiberglass resin, take it apart, and re-seal the fibers in your ladder like they were when it was new. Easy easy. You put wax on that thing, the fibers will still be there but resin will never stick. You'll ruin it.
Walter Matthau
08-07-2005, 12:02 PM #23Could be an old wives tale, but I have heard that the UV damages fiberglass ladders that are left outdoors.Originally posted by lusker
thanks
The fibers that are coming off means it is possible that the ladder is unsafe to use. The UV damage could be deeper than just the surface. Composites do not fail slowly, they fail catastrophically, often without warning. Fibers being released is proof that the outer resin coating has failed.
I do know that any type of concealing treatment, such as paint or tape on a ladder, violates OSHA regulations. The paint/tape hides damage. Your ladder, your fines.
If it was me, I would destroy it and buy a nice new US made one. Lot cheaper than going down the hard way.Proper Prior Planning Prevents Piss Poor Performance
"There is hardly anything in the world that some man cannot make a little worse and sell a little cheaper, and the people who consider price only are this man's lawful prey. It's unwise to pay too little.
When you pay too much, you lose a little money -- that is all. When you pay too little, you may lose everything, because the thing you bought was incapable of doing the thing it was bought to do.
The common law of business balance prohibits paying a little and getting a lot -- it can't be done. If you deal with the lowest bidder, it is well to add something for the risk you run. And if you do that, you will have enough to pay for something better."
John Ruskin
08-07-2005, 12:49 PM #24
Lusker.........don't be a cheap SOB
Before that relic mames or kills somebody cut it up......or give it to your brother-in-law
You can get a brand new one for around a hundred bucks or so.
http://www.wernerladder.com/catalog/...?series_id=128
08-07-2005, 03:15 PM #25
I could have sworn I read on this site (a year or more ago) about someone who had thier ladders re-coated every few years. This wasn't really a fix for a bad ladder, but more of a maintenence thing to keep this from happening.
08-07-2005, 10:04 PM #26
Most major malls have a "LadRestorer"
Right between the "Leftorium" and the "Scotch Tape Boutique"
Walter Matthau
