Results 1 to 12 of 12
Thread: Curb support??
    Apr 2003
    Levittown, PA
    Sometimes when I consider what tremendous consequences come from little things, I am tempted to think there are no little things!
    Apr 2003
    Levittown, PA
    New install, about 1month old.
    I personally like the flow of the whip!
    Impressive isn’t it?
    Feb 2005
    Coffeepot, Ohio
    Don't stand too close!! The wind might blow...
    If you can't push; pull... If you can't pull; GET OUT OF THE WAY!!
    Gone
    I think you guys make this up in your spare time. This can not be real.
    Jul 2005
    Field transition at its finest!!!!
    Apr 2003
    Levittown, PA
    The call came in as a no A/C. The building has 5 units and 4 were approved for replacement. One was still fuctioning. (See how I say was!) The reason I was called....... they wanted to know why the front of the space wasn't cooling when the unit was just replaced. And were weary about the other guys, so they called us out. Turns out the installers (quality that they were) removed the good unit and left one of the dead ones. When I seen how the new units were installed..... I wanted to puke.
    Sad but true!
    Jan 2003
    Kansas City
    The worst part of this is that they didn't just field hack this. They had to consider, design, build and install those I brackets....Thats at least 4 chances to stop the insanity. I always wonder what installers like this say to each other as they are getting off the roof or how they can say that other companies overcharge and rip customers off.-----------We really need state licensing and mandatory (every job) mechanical inspections.
    Arizona
    That is sad. Them Carrier units haven't been the most relaible either. You'll see that place again
    May 2005
    RUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUNNNNNNN!!!! !!!!!!!
    Initially, I was pondering as to what the original problem with this install was, then it came to me like a flash of enlightenment.
    THEY DIDN'T USE TREATED LUMBER!
    Teach the apprentices right... and learn from their questions and ideas.
    "Hey...just make it work, alright".
    Get back to work.™
    Kingston, Ny
    Where are these people from? 5.5
    Re using packaging for shims. 8.5
    Re use of disconnect 9.0
    Use of new whip 3.5
    Cheap transition on existing mount 8.5
    Use og Aluminum support 4.5
    Call back 9.5
    Post on "Wall of Shame" 10
    Unit out of level 8.0
    Customer afraid to call contractor 10
    Total 77
    Need to work on re using whips, cheaper supports. Now onto our next competition!
    Happiness is the only good. The time to be happy is now. The place to be happy is here. The way to be happy is to make others so.
    -Robert Green Ingersoll
