    Aug 2005
    My hot air furnace / AC unit gets most of its intake air from a vent on the side of the furnace itself. This means that it is pumping air from the basement thoughout my home. Is this a bad idea?
    Nothing wrong with it if you have some way for upstairs air to get to basement
    burlington county n.j.
    could be sucking backdraft down chimney if not enough air into basement. we are not allowed to pull return from heater area for this reason.
    Madison, WI/Cape Coral, FL
    Must keep the basement "positive pressure"! Back-drafting chiminey and sucking in soil gas(moisture and radon) a no-no. So more supply than return unless there is no door on the stairwell. TB
