    Aug 2005
    can i use a 3 ton air handler with a lennox 2.5 ton heat pump model 12hpb30 with out having problems?
    burlington county n.j.
    lennox lists that unit as matching up to some of their 3 ton air handlers. guess it would depend on exactly what you are matching to.
    you would normally get a 3 ton air handler with a 2 1/2 ton condenser. i price all my 2 1/2 ton systems with 3 ton air handlers and furnaces.
    make sure you install the orfice that comes with the condenser because if you dont youll wind up with low subcooling and low superheat.
    if installed properly it should give you a little more efficency.
    Aug 2005
    thanks for the info !
