Page 1 of 4 1234 LastLast
Results 1 to 13 of 40
    Feb 2005
    Dothan, Al
    What is the 'one' purpose of having a compressor in a refrigeration system??? In other words, what is the compressors designed function.
    I used to ask my class this question, on a test, after taking the basic refrig. course.
    Richard
    May 2005
    Mississippi
    Talking
    My guess is to "Compress"? I give up!
    Regards
    Sep 2003
    Ocean County, N.J.
    The compressor is a vapor pump. It removes the unwanted heat from one place and transfers it to another place where it makes little or no difference.
    May 2005
    Mississippi
    I was somewhat being a smart-a** in my first reply.
    From the hip and very quickly, here is my answer.
    The compressor compresses the refrigerant gas. This raises the pressure of the refrigerant and temperature,the refrigerant then travels through the condensing coils allowing the refrigerant to dissipate the heat of pressurization.
    As it cools, the refrigerant condenses into a liquid form and flows through the expansion valve/orifice.
    When it flows through the expansion valve/orifice, the liquid refrigerant is allowed to move from a high-pressure to a low-pressure area (evap. coil), so it expands and evaporates. In evaporating, it absorbs heat, making it cold.
    The evap coil inside the ahu/refrig/whatever allow the refrigerant to absorb heat, making the air downstream of the coil cooler. The cycle then repeats.
    Of course, this is completely backwards for heat pump in heating mode.
    However, I still stand by my first answer; "to compress"
    Have a great weekend everybody.
    Gone
    The compressor is designed to “circulate” the refrigerant in a closed system.
    Feb 2005
    Dothan, Al
    Keep in mind - is it necessary to have a compressor to provide refrigeration ?
    no you do not need a compressor for a refrigeration system.
    Jul 2005
    Orange County, NY
    The compressor does one thing
    Provides conditions necessary for a refrigerant to change state.
    Core
    leland nc
    compresses gas from a low presure to liquid at a higher pressure. this is its only function
    leland nc
    sorry not gas but vapor
    The one purpose of the compressor is to increase the temperature of the vapor.
    The way I see it...
    1. compressor - increase refrigerant temperature
    2. condenser - release heat
    3. expansion device - decrease refrigerant temperature
    4. evaporator - absorb heat
    The change in refrigerant pressure is a side effect and not a purpose or goal of any component of the refrigeration system.
    Feb 2005
    Dothan, Al
    redskin
    Where did you get yur training at ??
    Or who taught you that ??
    Richard
    ps - where you from?
