Results 1 to 10 of 10
Thread: wiring diagram
    Dec 2003
    Citrus County, Florida
    ran across an old one. it's a package heat pump, Kenmore made by Carrier, 20 years old, sears model # 867.814465.
    there are no labels nor owner's manual available. Need wiring diag for 24volt controls. Also, it uses the 621 type defrost board if that helps.
    thanks
    Doug
    Serving Northern Va and surounding area
    Go to http://www.SEARS.COM the web site will give you everything you need and a good Tech can make anything work.
    Dec 2003
    Thanks for the suggestion but....been there...no longer available. I hate the thought of having to rewire it. Someone has been in it over the years and has cut and taped off leads. UUURRRGGGGHHHHH!!
    Doug
    Dec 2003
    Correction, I've been told that this unit was made by Whirlpool. It is referred to as the "horseshoe"..
    Doug
    Feb 2005
    Central Alabama
    Check with ICP.Comfortmaker
    http://www.hvac-talk.com/vbb/showthr...threadid=81482
    Also check to see if this is what it looks like.
    Dec 2003
    Bama 101,
    the link does not work.
    thanks
    Doug
    Feb 2005
    Central Alabama
    sorry,
    __________________
    Feb 2005
    Central Alabama
    it's in pro section and i can not get picture to copy over, so i'll keep trying
    Dec 2003
    thanks, can you email it to m? dktv@aol.com
    Doug
    Feb 2005
    Central Alabama
    i'll try
