    Apr 2005
    Post
    my question is I have ice on the coil that goes to my AC unit(from the out). The unit is not blowing air or cooling, is it something that I can do or do I need A HVAC tech.And can you refur me to someone in the Charlottesville VA. area.
    Jul 2002
    Yes, you can check the filter and make sure there are no registers blocked. Then call a pro.
    Apr 2005
    Thanks for your reply. Another ? Once I change the filter and turn the system on what can I expect to see happen with the system? I'm still going to call a pro to check out the system for service and maintaince. Thanks
    Jul 2002
    Let the ice melt first. I said check the filter! was it very dirty?
    Try B.S. Boyers in Lyndhurst Area
