Results 1 to 7 of 7
    Sep 2001
    angola indiana
    H/O wants a humidifier and only possible option that I can find is a Humid-a-mist. The problem is I have never installed on of these and know nothing about its problems or lack thereof. Any one out there with experience on these that can help me out? Please?
    Sep 2001
    angola indiana
    humid-a-mist
    Does anyone have any experience with this?
    SE Michigan
    If it sprays through a nozzle directly into the air stream, then I dont recomend it. I have seen them cause more harm then good and they become clogged easily.
    “Now the freaks are on television, the freaks are in the movies. And it’s no longer the sideshow, it’s the whole show. The colorful circus and the clowns and the elephants, for all intents and purposes, are gone, and we’re dealing only with the freaks.” - Jonathan Winters
    i agree w/ coolwhip on the misting types.
    i don't know if this will help, but skuttle makes a flow-through under duct mounted type. i've never installed one and have only encountered one.
    there used to be a skuttle rep on here, try a search maybe you can find him.
    Sep 2001
    angola indiana
    humidifier
    Yes, I was refering to a nozzle induced misting spray. This is a counterflow furnace in a closet configuration and I just dont have room for anything else. Anybody out there have any other suggestions? For the humidifier I mean!
    in a house, Appomattox, Va.
    did one, took out a few days later.
    Maybe a central humidifier, wall mounted. Aprilaire makes one. Goes in closet or in basement space, can be ducted or has a supply grill on end of unit through wall.
    Col 3:23
    burlington county n.j.
    we use the mister type humidifiers on counterflow systems around here. one town of mostly slab houses with concrete pit for plenumn. would not use on metal duct in crawl space. usually add extension pipe after solenoid valve to get nozzle down below a/c coil. nozzles usually last at least one season.
