Results 14 to 21 of 21
Thread: a coil on top?
    Jul 2002
    robo, understand you statement now, your right. Seen lots of gaspacks rotted out. thanks
    Originally posted by Toolpusher
    What fan coil has electric strips and puts the evaporator above the strips ??
    Todays air handlers in the downflow position,have the evp. above the strips.
    I'd prefer them below,,but the downflow is UL listed .
    Nov 2000
    Eastern PA
    PTAC units usually are like this as well as some pancake style of airhandlers. When the heat strips are before the DX coil they must never be energized at the same time as the heat pump. On these types of systems you either have heat pump operation or electric strip heater operation, but never both at the same time as is the norm with the DX coil being before the heat strips.
    ...seek, and ye shall find;..
    Ecclesiastes 10:2 NIV
    Apr 2003
    Coleman, in mobile homes are all like this.
    I've seen them do it on the gas units too!
    Aug 2005
    On airhadlers the supply opening is smaller than on gas fired furnaces. And the blowers are smaller on air handlers. On most units they require 18'' sleeve on the supply opening to keep the static pressure up. So its not about the air flow over the coil but the staic pressure to supplied to the longest run.
    Feb 2005
    otors are smaller,interesting,as they can have more static then a furnace after you deuct the coil for the furnace,which the air handler has built in .What fan curve did you get that info from,Nordyne,as there air handlers are weak!
    Nov 2000
    Eastern PA
    Only Rheem/Ruud/Weatherking products have this problem and from what I hear on the grapevine they are doing away with that short air handler.
    Aug 2005
    coil on top or bottom
    First the Mfrs. have recommended that on Electric A/H, the coil needs to be on the bottom, if coil is on top and leaks, water and electricity(heat elements) do not go well together. Another note a p-trap needs to be installed so water can drain, as air will be drawn in through the drain line and could cause the drain pan to overflow, if connected on to house plumbing could draw fumes from house plumbing as well(stinky house).
    On gas furnaces the coil needs to be after the heat exchanger, the condensation will cause premature rusting.
    One reason the MFRs. have gone to stainless heat exchangers.
    There is other tech data for this type of setup the MFR. will be glad to answer for you.
