Results 1 to 13 of 35
    Aug 2005
    Smile .
    [Edited by overkill71 on 08-04-2005 at 08:02 PM]
    Jul 2002
    what was the amp draw on the compresser?
    Aug 2005
    on the black from contactor i get 10amps
    on the blue (s)(start) i get 5.1amps
    on the yellow i get 12.1(RUN)
    this is taken at the peckerhead of compressor
    thanks again
    Jul 2002
    How did that match up with the name plate?
    Aug 2005
    RLA is 22.7
    lra is 93......
    this is off nameplate on condensor unit
    cannot read anything on compressor really
    [Edited by overkill71 on 08-03-2005 at 11:59 PM]
    Jul 2002
    What was the result of your pump down test?
    Aug 2005
    i havent tried to pump the unit down yet....possibly looking for stuck 4way valve????
    Jul 2002
    Do you mean reversing valve?
    Aug 2005
    yep... thats it..the reversing valve..lol
    Jul 2002
    Why do you think its stuck? Did the customer put it in heat mode, in the middle of summer? You had low amp draw! If reversing valve was stuck, where it isolated the lines to the service vales, I think it would have a high amp draw.
    Feb 2005
    Dothan, Al
    overkill
    I think the system is empty of refrigerant - call a pro!
    Houston,Tx.
    Re: overkill
    That would be my guess also.
    burlington county n.j.
    Re: Re: overkill
    sitting there eqalized at 150lbs andits out of freon???????
    i don't work on heat pumps but i'm pretty sure that ain't it.
