Results 1 to 13 of 19
    Jan 2005
    Indianapolis IN
    I like the way this site is so direct in responding. While Iím a homeowner, Iím trying to distinguish the great installers from the others. Your help to educate us is appreciated.
    I'm a homeowner that hired a local company to install a new A/C. This was a Trane 5 ton unit replacing a 9 year old American Standard. Same company serviced the American Standard. The tech had a difficult time brazing a leak free joint at the evaporator. Not sure of the line sizes, but the evaporator tube was something like 1.25 inches and the line set was something around 7/8 inches. The tech didnít use a reducer coupler, but rather just used Channel Locks to crimp the large line to fit around the smaller and then attempted several times to braze the joint. He finally got it to be leak free. The odd thing was the original American Standard coil was connected the same way. However, it wasnít installed by the same company. Is this a common way to complete this joint, or are these Wall of Shame candidates?
    The tech did purge lines with nitrogen. The previous system had a leak in the system and that contributed to the system being replaced. The line set wasnít replaced. Had three estimates and all said the lines didnít need to be replaced. Is that what you would have done? Iím sure there are many other variables, but approximately how long should he have ran the vacuum pump to clear the line set prior to charging the system after he installed the new condenser and evaporator?
    Thanks,
    Bruce
    Senior Tech Guest
    Thanks,
    Bruce
    Although I prefer reducing couplings for neat appearance it is and has been common practice for years to pinch copper and braze. No line set? Let's hope the leak wasn't in it although if the right equipment was used a leak would have been noticed. As far as vacuum...no specific amount of time, rather a vacuum should be measured in microns with a quality micron guage, down to 500 microns, could take minutes or hours depending on as you put it "variables".
    burlington county n.j.
    would prefer to use reducing fitting. would NEVER reuse line set unless old one could not be replaced. what ever was in old system is now instantly contaminating new system.
    Apr 2003
    New line set, micron gauge for vacuum monitoring, and would have run the appropriate line set size for reliability and efficiency!
    Jul 2005
    Orange County, NY
    I find it amazing how many HOMEOWNERS come on this site and ask these questions.
    I will assume that you will start asking the tech. that is doing the work to see his micron gauge or ask him "Why didn't you change the line set....arn't you suppose to??
    Let me ask you this SIR.
    "If it took me 10 Hours to pull your system down to 1000 Microns (which by the way is my perferred evacuation) would you be willing to pay $95.00 Hr for this job?????
    Would you pay me $95.00 Hr. to watch a Micron gauge??????
    Can any homeowner answer this question??
    Jan 2005
    Indianapolis IN
    Thanks for the quick replies, now for a follow-on question. Isn't a micron a thousandth of something? Iíve seen vacuum pumps for woodworking vacuum clamping rated in capacities such as 25 inches. What is the micron rating in the A/C vacuum pump?
    Thanks,
    Bruce
    Apr 2003
    Switched to homeowner mode... for a sec.
    $95 an hour!
    I work at a factory and make $15! You are charging WAY to much. You are a crook!
    Ok, I'm back to tech mode.
    Senior Tech Guest
    Micron...one millionth of a meter...core...valium...the wonder drug.
    Apr 2003
    1" = 25,400 microns. (system should hold under 500)
    For more infomation on vacuuming priciples go here.
    A lot of valuable information is at the above link!
    Jul 2002
    How is the system running? Give us a little back ground here.
    Jan 2005
    Indianapolis IN
    Core, you seem to be way too sensitive. I've always been interested in anything to do with construction and learning new things. I was curious what others in the industry would have recommended. I thought this site was created to try to educate everyone. Sorry if I offended you. My goal is simply to understand HVAC technology better.
    The answer to your question about watching a vacuum gauge is: I contracted with a company to install a new Trane A/C. I believe that I paid to get the system installed properly. If installed properly means someone has to watch a vacuum gauge, then yes, I agreed to pay that price.
    Again Core, Iím sorry if I offended you.
    Thanks,
    Bruce
    Apr 2003
    I'm curious as if there was a load calc preformed?
    Jan 2005
    Indianapolis IN
    Chill, the system is running just fine and keeping the house nice and cool in our record heat summer. The old system developed a leak in the evaporator coil and the compressor stopped running. All three companies indicated replacing everything but the line set on a nine year old system was the proper way to go. That sounded reasonable, so I contracted with the one that had done other work for me in the past. That was the middle price estimate. The lowest price didnít spec a Trane, so being lower may not have meant much.
    Thanks,
    Bruce
