Results 1 to 12 of 12
    Jul 2005
    A/C units rooftop 1.5 to 2 tons, evaperator does not have schrader valve at evap.I can not measure PSI of low side,
    can I just measure it at the compresor, can I add 2-3 PSI
    for an average pressure loss in the refrigerant line from the
    evaporator to the compressor.Now if that's so,I would be ading PSI to the low side compresor reading,
    if I were to do this on the high side at compresor to evaperator will I be substacting PSI instead of adding ?
    Jan 2003
    Kansas City
    No Comment
    [Edited by james mo on 08-03-2005 at 11:32 PM]
    Apr 2003
    The below is a comment from this thread.
    posted by dancsurf
    Keep up the good work guys, this is a great site,
    I won't bother you with my DIY questions any more,
    I'll research the database,
    Thanks again
    So why are you still here, asking technical HVAC questions?
    And how did you get your creditials?
    Or better yet, why did you feel like you had the right to apply for a pro's membership?
    (we can't help DIY, due to site rules )
    South Dakota
    Originally posted by james mo
    Measure and calculate superheat at the condenser. Most evaporators do not have a schrader at the outlet. Don't bother trying to guess at the pressure drop because it is just a guess. Superheat at the condenser is what you are most concerned about unless you are trying to diagnose a flaky TEV or suction line restriction.
    Superheat is not measured at the condenser but subcooling is. Superheat is measured on the low-side.
    Apr 2003
    This guy is not in the HVAC industry. He is a DIY all the way!
    (please read the thread in my previous post)
    Jan 2003
    Kansas City
    Talking
    When I said condenser, I was referring to the condensing unit in a residential split system. The low side of the outdoor unit that is...Hee Hee
    Jul 2005
    jultzya
    Boy are you persistent,
    you do make me laugh !!!!
    That's a good thing,
    jultzya, I am a professional HVAC repair person, I am servicing 20 unit apartemant A/C, as well as other handy man stuff.
    My credentials are mostly learned from this good site and some books.
    I am not a DIY,
    by the way , the A/C I installed in my house (attic)works fine, the heat is a blast! only problem was with the condesation not draining properly fixed that!
    No leaks, cools fine, heat is great, duct work seems to be very well balanced,
    This was a hard job for 1 person to do,I do no recomend it
    to anyone......
    Are you still not convinced ????
    Jul 2005
    jultzya
    JUst stop it already!!!!
    I'm trying to do the right thing by learning,,,
    Apr 2003
    Re: jultzya
    Originally posted by dancsurf
    I am not a DIY,
    Did you forget that you posted this...
    posted by dancsurf
    Thanks again
    I didn't!
    Nice try though.
    Senior Tech Guest
    Professional?....yet to be proven. This is not your typical "handy man" site...be prepared to pay the hazing dues.....wheres Dice when you need'm...
    Jul 2005
    jultzya
    Just because I ask DIY questions does not mean that I am
    I am learning for my work, HVAC is part of my work.
    BooHooo, you hurt my feelings
    Apr 2003
    Guess you missed this post...
    Originally posted by Toolpusher
    Going into the HVAc field starts with going to classes.
    Be it day or night.
    Not On HVAC-TALK .com
    ..in this thread too?
    You can't come here and think we forget... cause some of us DON'T!
