    May 2011
    HRV for kitchen exhaust
    Is anybody aware of a UL compliant HRV that can be used on kitchen exhaust?
    Poestenkill, NY
    Quote Originally Posted by Droman View Post
    Not gunna happen with a type I hood.
    Madison, WI/Cape Coral, FL
    That would be a greasy mess!
    Is this for a commercial or residiential application and what region?
    Regards TB
    Apr 2011
    Coastal Maine
    The grease would kill the exchange wheel. Bad idea.
    Boise, ID
    Actually they used to do this.
    I recently ran across an old Frank and Church system on a cook line that was probably 40' long. It used a plate frame HX with an automatic steam wash down. The system was 30 years old, I imagine, and know longer functional in auto mode, but still worked....hand mode...which they did. They wanted to fix controls but I would not touch it. There were many many more current code violations on the system.
    Politicians need to be changed like diapers, and for the same reason.
    Mark Twain
    Nov 2000
    Memphis TN USA
    Have seen a couple restaurants with swamp cooler on the kitchen make-up air
    If the superheat ain't right it ain't charged right.
