Results 1 to 6 of 6
    Jan 2003
    Kansas City
    Just thought it was interesting. It would have been a whole lot cheaper just to hard pipe that line.
    Rochester, MN
    That's the new line running to? I would of T off inside of the house than near the meter..
    The yellow gas flex is getting pretty common.
    Memphis
    I bet that never saw an inspection. In Memphis, we can run that inside, but have to hardpipe anything outdoors. Yeah woulda been a whole lot easier to hardpipe it. Those compression fittings are about 8 bucks a piece.
    Here in Alberta, Can. We can use Gas-Tite, only if it's protected from potential mechanical damage on the outside. But it's more common to just hard pipe it. Our inspectors, would likely give it a 'thumbs down' in this case.
    Teach the apprentices right... and learn from their questions and ideas.
    We supply an apartment complex in NJ that ran Ward-flex from the outside meter sets, along the outside walls, to each apartment.......don't want to know how that got approved
    Jun 2005
    Thumbs up
    look beter too. the rust from the termination fitting is only going to get worse and run down the wall
