Thread: A/C not working
    Aug 2005
    Last night I noticed that was house was getting rather warm. I tried to turn down my thermostat and the A/C never kicked on. Usually I can here the stat click and see the spark. This time nothing. I tried popping the breakers in my box, but that didnt do anything. I'm wondering if the stat is bad or if the problem is more serious. I called a few places and one said to hit the reset switch on the outside unit. I couldnt find it since that side is up against a tree. The outside unit is a rheem rpca-024jcs heat pump. any thoughts?
    SE Michigan
    It could be any number of things. You need to have a tech look at it. There may not be 24vac present and they need to find out why.
    “Now the freaks are on television, the freaks are in the movies. And it’s no longer the sideshow, it’s the whole show. The colorful circus and the clowns and the elephants, for all intents and purposes, are gone, and we’re dealing only with the freaks.” - Jonathan Winters
    Florida
    Definitely call a tech. You can usually see a spark where? The condenser is up against a tree? 2 problems right there.
    If you can usually see a spark , thats not good and the tree? well if you cant get in there how will anyone else be able to?
    Aug 2005
    usually when i turn the thermostat down to where it kicks everything on i could see a spark and here it click on. you can still get the access panel off to get inside the outside unit
