Results 1 to 13 of 18
    Aug 2005
    My partner and I were called to a friends house to work on their residential unit. The Cond fan and Compressor share the same start cap, and one "leg" of the cap was burned out, and the Comp was not running. It was a 35 microfarad, but we only had a 25 and a 10 microfarad, so we wired them up together as a repacement, the unit started up fine, and was blowing out hot air, with a low side press of about 85, on a 95* day.
    A few hours later, the owner of the house, who is a friend of the family, called and said that air was being blown out the sides of the condenser rather than the top, and that he's sure that it used to blow it out the top in the past.
    Did we somehow reverse the direction of that cond fan or switch the run and start windings?
    So what company do you and your partner work for?
    "It is what it is."
    You probably forgot to check the flux capacitor.
    "It is what it is."
    leland nc
    if the fan and compresor used the same cap there should have been a nother number on the old cap for the fan. it was a daul cap and you have to put a separate cap in for the fan motor rated for the motor.
    Run Cap
    should be a run cap, and sounds like you got it wrong.
    Aug 2005
    The original was a 35/5 microfarad. We used a 10 and a 25 uF capacitor, I believe the 25 uF was a 25/5.
    I'm thinking the Comp gets the 35uF and the Cond fan gets the 5uF?
    Would using the wrong size cap make the fan spin the wrong way though?
    I just graduated, so I'm out with a buddy that's retired, but still does side jobs, so I'm just a beginner.
    Aug 2005
    I'm gonna head over there in the morning and check the wiring diagram. I didn't do the wiring, I just watched and tried to learn something.
    leland nc
    reverse the cap wires for the fan motor and it should run the correct way
    Jul 2002
    You and your friend need to pay more attention. When you were putting away your tools didn't you notice anything hitting you in the face?
    What would that be Chill?
    "It is what it is."
    is that a test question.....hmmmmmm let me see.....
    That would be air blowing out of the condenser instead of being drawn into it
    lets see if I remember correctly, connecting a 25 and a 10uf cap will not = 35uf
    It will if they are wired parralel, but not in series.
    Jul 2002
    I can't beleive someone would over look something so obvious. Two people no less!
