Results 1 to 2 of 2
Thread: York service valve question
05-01-2011, 09:25 PM #1
- Jan 2008
- 49
I have to pump down and change out a York h2cb036s06a. I found at the service valves are not the allen type I am used to seeing. they had deep caps on them and when I took one off, there was a pin underneath. It seemed to move with the cap as if the tightening of the cap depressed the pin to open the valve. Is this correct. If this is, then I assume that taking the cap off will allow the pin to come up, sealing the valve. I didnt look that good cuz I didnt expect to have to deal with this unit, but it turned into a full system upgrade.
05-01-2011, 09:32 PM #2
Professional Member*
- Jun 2007
- Round Rock
- 2,919
Take your recovery machine out and be done with it. You're gonna have to do it at some point when you recycle the old machine anyways. Save a step. If will probably only take an extra 15 minutes or so.
I like DIY'ers. They pay better to fix.
