Results 14 to 26 of 30
    Jul 2005
    Biiscuitnt; but there will still be more rpm carried into the 8" because of the 10" (2" diam. gain in volume.)
    Air don't abruptly slow down when confronted with a streamlined resistance, it slows gradually, and depending on the (tel)total euivalent length of the run, it may well achieve some added gain in air flow at its termination point.... As to exactly how much, only instruments (air measure)will tell.
    Originally posted by davidr
    I would say increase the size of the duct all the way to the boot,or add an additional branch.
    Depends on how much CFM you are short to the room. [/B]
    I'm sure this would work better. The problem is that this duct (to master bedroom) travels between first and second floors and cannot be accessed without tearing up the drywall ceiling. The plenum and air handler are in an attic above the kitchen area and garage which is only one story. I can get to them but the duct disappears between the floors after a few feet.
    I thought of a duct booster fan but the pros here don't seem crazy about them and it would have to be at the start of the run. I also thought of putting the duct on top of the plenum (it's a vertical upflow system) but that idea seems risky. Right now all the ducts (which all branch into 2 to four smaller ducts) come off the sides of the supply plenum. I've partially closed some of the other registers but that only seems to reduce airflow from them without helping the two in my bedroom that needs more air. Note: I was wrong in my opening post. These two registers are fed by a 9 inch, not an 8 inch, but I'm still wondering about increasing the takeoff on this duct.
    May 2005
    Mississippi
    I am not going to beat this one to death, take-offs are cheap, go ahead and give it a shot, it wont hurt anything. You could also try installing some manual volume dampers in the other ducts coming off the plenum to restrict the airflow to those trunks. just be careful if you do this and dont get carried away with closing off ot much adn restricting the entire system.
    regards
    1.Move it to the top of the pleunum,add a damper if it's too much air flow.
    2. http://www.fantech.net has booster fans that work and with static readings.current and desired cfms ,will size the fan for you.
    [Edited by dash on 08-02-2005 at 03:29 PM]
    Jul 2005
    Orange County, NY
    Just how much flex duct is there on that run?
    Guessing 25-30 feet of 9-inch flex, then one of those awful triangle boxes, then two 6-inch flex a few feet to the registers.
    Ducted return large enough,or a good retuen path??
    I'm okay there. Rarely close the door.
    Jul 2005
    Orange County, NY
    FatBob
    That sounds like your problem.
    1. To much flex.
    2. If designed at (.1"WC friction) then 9" run = +(-) 320 CFM. 6" run = +(-) 110 CFM.
    110 + 110= 220 CFM
    320 - 220= 100 CFM (that may be availible in that duct)
    Increasing the 9" to 10" would be a huge waste of time and money.
    What does the 2 6" runs feed??
    FatBob
    1. To much flex.
    110 + 110= 220 CFM
    The 6" go to two 6x8 one-way registers. The registers were the 3-way stamped kind but I replaced them which helped a little. I don't think the registers are the problem. I also think the installer was pretty careful to seal the ducts and avoid unnecessary bends and kinks. I just need to get more air into the 9" trunk.
    Jul 2005
    Orange County, NY
    Why would you think the installer was careful???? To me 20 to 30 feet of flex duct is careless! To much friction loss in flex duct.
    To maximize these 6" ducts you may have to remove the flex and run insulated hard pipe.
    How big are the rooms that are feed by the 6" ducts?
    If you can repalace the tri-box with a wye,that would help,if is all unaccessable ,number 1 or 2 above will solve the problem.
    The TEL of a Tri-box is high enough that ,just chaging the takeoff,will not make enough difference,I had previously assumed this was one 8/9" run to a grille.
    Thanks Dash et al. for your suggestions.
