Results 1 to 13 of 21
    Aug 2005
    I'm looking for some feed back on the non name brand units. Like Goodmaan, American Standard, Comfortmaker... I have looked at the websites and to a non a/c person it all looks the same. I am building a house wondering if it is worth the savings to use one of the companies. Any information would be geat..
    Mar 2001
    Building a new house you are actually better off making sure you get a quality install regardless of brand name. Make sure you get a company that will do a heat load calculation and install the equipment PROPERLY. Personally I would choose to spend a little more for the HVAC than look to save on it. You will be breathing its air for the next couple decades and paying the power company every single month.
    "Non-Brand" equipment should cost less. Be advised if you are using a builder he more than likely already has a low end unit already planned for that house unless you pay to upgrade.
    The price difference,is often because one contractor ,works for a lot less,pays less ,has less benefits for their coworkers,etc.,etc..
    In our are the price difference between brands at the wholesale level is not what makes someone 10% less then us.
    Each brand has a good,better ,best type lineup in the products.I'd look at the best in each.
    The design,install and service after the sale,is critical,to equipment life,your comfort,and in rare cases your safty.
    You builder,may not give you any option on which HVAC contractor will do the job,ask before signing on the dotted line.
    Aug 2005
    So how do Comfortmaker and Bryant fir in the good, better, best lines?
    Yes they both have good better and best in their equipment. What is more important is the company that is going to properly size, install, maintain and service.
    Price alone is scary. Quality work is worth the extra you pay up front for it.
    american standard is one of the best systems out there,same thing as trane. i would not use one in my home though. i dont like having to remove all the panels to clean the condenser coils among other things i dont like about am.standard trane product. now my opinion is that bryant reliant systems are the best you can buy.
    the only differance between say a goodman and a top of the line bryant,carrier or lennox system is not that much more money and will give you a system that will last more than 12 or 15 years. or buy the cheap stuff and spend the money fixing it.
    and most important will be the installation and if not done properly will lead to compresor failures and high electric bills.
    They each have some form of good,better ,best within the the brand.
    Top of the line ,has variable speed indoor fan motor,two stage gas heat,quieter outdoor unit,higher SEER,two stage/speed outdoor compressor,etc.,etc..
    Most of these and to "Your" comfort.What's true comfort worth to you??
    American-Standard is a world-known NYSE company. I wouldn't call it a "non name brand"!
    Nov 2000
    Eastern PA
    I was thinking the same thing baldy.
    Also, with more Goodman units in homes then any other singular named brand, I don't think Goodman qualifies as non-brand either.
    To answer the question though; it's basically all the same stuff.
    ...seek, and ye shall find;..
    Ecclesiastes 10:2 NIV
    Jul 2005
    In reply to the oft repeated advice to get a quality instal, I have to say, after the experience of getting 3 estimates for different brands, it's impossible to judge from the estimate process. With the help of this site I was able to rule out the lowest bid because the guy said he would 'pull a vacuum if I insisted on it'. The highest bid that was 4x (yes 4x) times the low bid guy came from what appeared to be one who followed the rules. Wore plastic galoshes over his shoes before stepping into the house (which was a little extreme), did a load calc (don't think it was Manual J since it took only 15 mts but did use window measurements and R-values), gave me a no quibble guarantee etc. BTW the load calc came up with 2T but was moved up to 2.5T (which is what I have), because of the bonus room that is tied into the downstairs. So what's the point if a fudge factor is used in the end. But is it worth 4X to pay for first class treatment. Not when every manufacturer regardless of his stature always seems to say (after you've purchased the unit) " heat pumps only last 10-12 years on the average". I wish the quality installers would talk to you about the things that they do to ensure quality. In the end I would say get references...
    The "Burgh"
    Comfortmaker is also NOT a "Non Name Brand" being that it is a division of International Comfort Products which is a division of UTC, also a NYSE listed Company.
    Feb 2005
    GEORGIA
    You might want to leave work at work unless somone ask you a tech Question about the brand you rep..
    "Value our Differences"
    Aug 2005
    Sorry didn't mean to offend anyone by calling their brand an off brand. Being a person that knows nothing about HVAC and would like a little help undeerstanding the different lines. Maybe I should have refered to them differently. I only know the big names in the business..ie. Trane and Carrier.. Doesn't in anyway mean to slight the others. Just looking for information if one has a better reputation than the others. I have been told to stay away from Janitrol. But to tell the truth I don't know anything about them either. Is any brand seem to be made cheaper or break more often than others. I don understand now that the guy doing the install means almost as much as the brand. So please give me your opnion if I should steer away from some brand.. Thank you..
