Thread: New Furnace
    Jul 2005
    Hi. I have a 4 year old, 2 1/2 ton Trane air conditioner that is running constantly when I set it at 76 degress or lower. It really had a hard time cooling when temperatures hit 100+ last week. I have a 22 year old Carrier furnace. My house is a little over 1300 square feet. I had a service technician tell me that the problem is with the old furnace, not the air conditioner. Do I need to have the furnace replaced as he suggested? Also, if I need a new furnace, does it have to be a Trane or can I use another, less expensive furnace.
    Louisiana
    Well you can have a tech clean the inside coil and also have him/her clean your blower motor wheel if needed. NO, you don't have to buy a Trane inside unit, but it does have to match up with your outside unit
    SE Michigan
    Go with a good warranty and a good installer. You better hurry if you want a 10 or 12 seer model. It would also be wise to have a load calculation done on the home. This will tell you how much heat gain and loss you have and let one size the new equipment accuratly. Good luck!
    “Now the freaks are on television, the freaks are in the movies. And it’s no longer the sideshow, it’s the whole show. The colorful circus and the clowns and the elephants, for all intents and purposes, are gone, and we’re dealing only with the freaks.” - Jonathan Winters
    I sure wouldn't dispose of a 4 year old unit!
    Find a GOOD dealer. The only thing the old furnace does is move air. If it ain't moving what it should be, fix the problem. Of course it takes a good duct system too.
    New indoor coil with that choochoo,or not?If not get a matchng one ASAP!
