Results 1 to 10 of 10
    May 2003
    AL
    Does anyone have any pics of a cracked goodman heat exchanger? Preferably M# PG036075-1AB. If so please post.
    May 2003
    AL
    g
    Apr 2003
    Why would one ask this?
    chicago suburbs
    it should be re-titled has anyone NOT seen a cracked HX on a Goodman.
    slide slide slippity-slide
    with switches on the block in a '65
    FILL OUT YOUR PROFILE!!
    May 2003
    AL
    for training purposes jultzya
    For training purposes jultzya. Showing stress points. Certain models crack in the same places.
    P.S. tinner73, I know we've all seen it but I was looking for photos.
    May 2003
    AL
    Paysonhvac
    Heck I figured Paysonhvac would send me a book of them.
    Apr 2003
    Sorry, don't have one for that model.
    YET!
    Nov 2000
    Eastern PA
    Well, that is a packaged unit with a clam shell heat exchanger with "O" rings. Most of those units will have popped "O" rings before there are any actual cracks in the heat exchanger.
    Another common failure of package unit heat exchangers is burnout at the first turn of the clam shell chamber routing. This is due mostly to moisture collecting in the heat exchanger during down time or from moisture condensing on the heat exchanger during the cooling season.
    The same failures you will find on this Goodman model will also be found on any other brand using the same type of heat exchanger.
    ...seek, and ye shall find;..
    Ecclesiastes 10:2 NIV
    Apr 2003
    Robo, why do manufactures produce package units with the evap coil before the HX?
    Seems like they wouldn't want the condensation on the heating side.
    May 2003
    AL
    Hey at least the latest goodman/Amana gaspacks I've seen have the Heat exchanger before the evap coil. Amana musta taught them that because the've been doin it for years. I have never found an Amana chamber cracked, have ya'll? I can't say that about any other brand, personally. Not knocking any brand, just an observation.
