Results 1 to 13 of 16
    Apr 2011
    Canada
    Confused Need advice on Reverse valve problem
    I have a xp15 4 ton lennox heat pump that i'm working on and it's totally fine when in cooling but when i put it in heating my low side drops down and hovers around 50-58psi while the high side is up between 300-320psi. Ambient was around 10 degrees F. On the reverse valve the top discharge pipe is around 150 degrees F and the suction line heading to the indoor coil is around 130 degrees F and the other pipes are around 0-6 degrees F. I think the slider isn't sliding over all the way when in heating, i've tried tapping it with a hammer as well as energizing and de-energizing "O" to loosen the slider, but nothing seems to be working. Does anybody have any advice on whats going on? Thanks
    Apr 2010
    Minnesota
    I think your RV is fine.
    Jul 2001
    maryland
    So what's the problem again?
    Saving the world...one service call at a time.
    Oct 2005
    Pacific Northwest
    Quote Originally Posted by dunkman View Post
    Or "was" fine....
    Apr 2010
    Minnesota
    Don't hit it with a hammer any more.
    Seriously though, what were you called there for?
    Oct 2005
    Pacific Northwest
    Apr 2011
    Canada
    I was called out there because the compressor was locked out on low pressre, it's a R 410 system and the pressure switch trips when it would drop below 25 psi.. when in heat mode my pressures should be around 100psi or so low side and 300psi or so in high side.. the temp between the the discharge port of the reverse valve and the suction pipe leading to the indoor coil is about 20 degree F difference, shouldn't they be roughly the same temp if the valve is functioning properly...What would you suggest might be the problem?
    Follow the instructions in the below thread, and read the second thread.
    http://hvac-talk.com/vbb/showthread.php?threadid=116113
    http://hvac-talk.com/vbb/showthread.php?threadid=1241
    i was going to ask if it was a 410A, but since that info has a finally been divulged, all i can add is What possessed you to hit it with a hammer?
    Virginia
    you need to call your service manager and ask for some training on heat pumps
    Fl
    A reversing valve got me the other day
    Fort Worth, TX
    You may have buggered an otherwise perfectly fine reversing valve by hitting it with a hammer.
    I think your problem is elsewhere, but now the RV might be added into the mix, furthermore adding insult to injury.
    Building Physics Rule #2:
    Building Physics Rule #3:
    sneakr76.
    If you think your vapor pressure on a R410A system should be around 100 PSIG in heat mode at a 10F ambient. You need to take some courses on heat pumps.
