Results 14 to 17 of 17
Thread: hoists
    We have had a 520 lift for 25 years. They haven't changed the design in all of that time. Parts are readily available. We have replaced every part including the casters.
    Metro ATL
    We have one of those that we use quite a bit to place AHU's in ceilings. We love it. The only downfall as mentioned is having to lift the equipment up on to the platform (about 4'). It is also not the greatest tool if you are planning to lift the load and then move it horizontaly. The load becomes very unstable if not centered. Also, as the load is removed from the lift, you have to requlate the pressure carefully or it will continue to push when you don't want it to unlike a mechanical lift.
    Jul 2002
    Slacking off right now
    I have used two versions of that
    the one I have used the most is up to 12 ft and fully collapsed its just ubnder 4ft
    they will lift 500 lbs
    I have used them mostly for low unit heaters or in ceiling heat pumps.
    You have to have the weight centred
    they will work with nitrogen and freon in a pinch
    they are GREAT!
    Watch the ram if you slid a load off the platform will jump up till it hits something or reaches its max extension
    Ive had the 5 ton square mcquay heatpumps and the 10 ton square mquay heat pumps on them as well just have to be centred for weight
    the beauty is that there's no mast at the side to get in the way
    they are super easy to get into elevators and in and out of your truck too
    www.vetopropac.com - The best tool bags on the market - The offical tool bag of choice by techs everywhere
    Arguing with some people is like wrestling a pig - eventually you realise the pig actually enjoys it
    Gonads serve a useful purpose but are no substitute for brains
    step 1) man lifts unit
    step 2) unit falls on co2 tank
    step 3) valve breaks off of co2 bottle
