    As the weather gets hotter, the ice maker seems to make less ice. Why would external temp affect how much ice is made on the inside of the freezer?
    May 2005
    Is the condenser coil clean ?
    burlington county n.j.
    ice makers are rated at 70deg air 50 deg water. as either one rises in temperature ice production goes down due to longer cycle times. the hotter it gets the more ice you need and the less you get. one of lifes injustices.
    Dec 2003
    Nevada
    It is really an issue when the condenser is outside ,and if you add a dirty coil as stated earlier it will get really long
    Quote
    “Engineers like to solve problems. If there are no problems handily available, they will create their own." Scott Adams
    "We can't solve problems by using the same kind of thinking we used when we created them."
    Albert Einstein
    Feb 2002
    Yuma, Arizona
    Amen
    Here that's a fact of life.
    Try telling a restaurant owner that some out of town company sold him a 600 lb unit and IT WILL NOT make 600 lbs in a normal working day (say 8 hours!). They say that's what they were told they will make..... Ha Ha..
    We tell them to call the seller back, the unit is working. It gives you 450 lbs in 24 hours your doing good.
    ( Air temp over the condenser at 110°f and water temps at 85°f.)
    Yuma
    What is snow? Is it that white stuff in a freezer?
    Jun 2001
    San Diego, CA
    yep yep, just did an IceOCrapic 0806 today. Rated at 1094 lbs / 24hrs - it's just barely making 610. 85* ambient, 83* water. She's giving it all she's got.
