Thread: Why upstairs?
    Apr 2005
    dallas
    Why put the smaller unit upstairs.If you need 5 tons of air,Why put 3 tons downstairs and 2 tons upstairs?Why not 2.5 tons up &2.5 down?
    Apr 2005
    dallas
    Most of the residents complain about how hot it is upstairs.Almost 90%.Most of those customers have the smaller unit upstairs.
    Jul 2002
    Zelienople, Pa
    Run load calculations on the 2 floors and this will tell you what goes where.
    Jan 2003
    Kansas City
    That sounds like a rule of thumb heat load calculation. 800 sq ft upstairs is a 2 ton a/c and 1200 sq ft downstairs is a 3 ton. A proper heat load calculation determines how much cooling you need on each floor and in each room. Sounds like this may not have been done properly.
    what did the installing contractor determine when they did the manual J
