04-28-2011, 07:27 PM #1
- Apr 2011
- Joliet IL
- 17
baxter 300g oven rotisary wont stop
im trying to find a schmatic for this oven and some advice the rotisary will not stop when the doors open ive tried to adjust the door switches i have replaced the relay the old won was welded together and trying to get parts or help from hobart and baxter is impossible
04-29-2011, 06:52 PM #2
- Mar 2008
- Over the river and through the woods
- 116
Lemmee guess, Dunkin Donuts.....There is a rack location reed switch (N.C.) attached to the roof of the oven at 9 o'clock and a magnet attached to the pulley. Check to see if it is stuck closed. Also check and see if the bracket holding the magnet is attached. The rack will rotate until the magnet engages the switch. The inputs to the door switch assy come directly from the control board. Good luck!
04-30-2011, 05:58 PM #3
- Apr 2011
- Joliet IL
- 17
05-01-2011, 05:47 PM #4
- May 2006
- 11
Baxter is part of Hobart.
www.hobartcorp.com
05-02-2011, 05:05 AM #5
- Apr 2011
- Joliet IL
- 17
