Results 1 to 13 of 18
    Western New York
    Never trust a disconnect
    Never trust a disconnect- always use your meter.
    Just a reminder. I found this today on a commercial W/I cooler condensing unit.
    Experience is what you have an hour after you need it.
    Apr 2010
    Minnesota
    Ran into the same scenario a couple weeks ago. Some jerk bypassed the disconnect. Isn't it required to replace a bad one if there's no way to shut the unit down from the roof? I told them they need a new one but I don't know for sure that it ever got done.
    Jul 2010
    So-Cal
    I found one that was wired wrong..the main feed wires from the breaker were coming in the bottom of the fuses and the load wires were coming out the top. So if you switched the disconnect off your fuses were still hot. Not good if you had to replace a fuse.
    Apr 2010
    Minnesota
    Quote Originally Posted by jackintheboxtec View Post
    Hate that. Causes gray hairs.
    Southold, NY
    Quote Originally Posted by baub View Post
    Safety first Guys & Gals.
    Always Check Never ASSUME!
    Dec 2010
    Va
    There are alot of Hacks in this bussiness unfortunately! You never know who worked on that unit an what they BYPASSED or CONTINUELY reset. When I open the circuit on a disconnect, I at least always push in all contactors. I work on familiar equipment as well. So I know the guys that have been there before me. But you should always use your meter....It just might save your LIFE!.....And that my fellow Brethren is worth it!
    Dec 2010
    Woodbridge Twp, NJ
    I wish i had the animated gif of Hitler from Inglorious Basterds yelling "Nein! Nein! Nein! Nein! Nein!"
    It would go perfect here.
    Every customer you take for granted today will be someone else's tomorrow.
    Sep 2009
    S.C.
    I found a residential unit (on a roof) straight wired in the Disconnect. I pulled the disconnect then pushed the contactor in with a Sharpie. Vrooooom, running!
    Yes, I know I Shouldn't But I Just Can't Help Myself...
    Feb 2011
    Indianapolis, IN
    Thumbs up
    Never trust a unit service swith either.... or that the water is off, or the king valve is off either !!!!
    Mar 2011
    Northeast Missouri
    Wow thats scary. Makes you ask what tech in their right mind???? A few years ago I "assumed" on a three pole disconnect. I still had one leg hot from the broken switch, I will never make that mistake again. The rule I go with now is that "if its not dead, you are".
    California
    This 277 leg will bit ya too, always verify!
    Jan 2006
    DFW Metroplex
    WTH........Doesn't anybody use the old 7/8" ACR 'slow-blow' fuses anymore!!??
    Just kiddin'
    "The problem is the average person isnt tuned in to lifelong learning, or going to seminars and so forth. If the information is not on television, and its not in the movies they watch, and its not in the few books that they buy, they dont get it" - Jack Canfield
    Nova-Scotia, Canada
    I was working on a 600v rooftop rtu and I somehow flicked one of those chinsey disconnects with my knee when I was checking the fan capacitor. Luckily no load. Reminder that you can become a conductor.
