Results 14 to 21 of 21
    What's wrong with the ground, unless it is a sucky HP I mean, and ya get lotsa snow.
    Hey cockroach, don't bug me! ©
    Nov 2000
    Eastern PA
    GDI's (Goodman Distribution Inc.) in my region sell them. They are great for the landscapers and make it easier to service the units when they are up off of the ground. Also, no varmits live under the units when they are mounted like that.
    ...seek, and ye shall find;..
    Ecclesiastes 10:2 NIV
    chicago suburbs
    they are used when the ground slopes away from the house steeply. i guess you could pour a pad but this has to be easier.
    FILL OUT YOUR PROFILE!!
    Although I prefer ground mounted units... we have these type of frames built at a local welding shop. We prime and paint ours Black, but any color will do. We use six concrete anchors (3 on each side). Some customers want them on their Wood foundations, so we lag bolt them on with big ass lag bolts... but it's a pain to find the studs especially after the parging is done.
    When we set the condenser on... we lay down strips of Cork/tape and use as many self tapping sheet metal screws to secure the unit to the frame. I did some in 1979. and the unit is still there, the frame needs a little TLC in the paint dept. but still secure.
    Most installations, have the units about the height yours is, but some customers want them as low as possible.
    Sofar, I've only had two units transmit vibration into the house. One was because of a compressor problem, the other was on a wood foundation. We initially installed the unit on wall brackets because they wanted A/C before they landscaped the yard (common here). So when they complained of the vibes... I just moved the unit onto a sidewalk block, and we even got to keep the brackets for the next job.
    Oh, and on that job, I got bit by a big black spider too!
    Just to add a bit to the Spider thread.
    Teach the apprentices right... and learn from their questions and ideas.
    manitowoc wisconsin
    Those brackets look pretty chincy to me.I do not like the idea of a gusset at what about a 20 deg angle?
    Take your time & do it right!
    They should be longer 'arms' against the wall... and gussets at 45 deg. angle... no acceptions.
    Dec 2001
    Chicago, N/W burbs
    Maybe this unit could use a set.
    photo courtesey of Hydrocarbon
    R2B4BTU
    This has got to be in California!
