Results 1 to 13 of 26
    Jul 2005
    I'm maintaining apartement roof top units.
    One unit does not cool well at all,
    it's a 1 1/2 ton Rheem , very old.
    low side is 60, high side 315 with a slight flutering,line temp 110 or more ? difficult to take super cool/heat readings
    sorry it was very hot on the roof and could not wait to get out, was there for a few hours.
    Any ideas on what I should be looking for to make it work correctly ?
    Apr 2003
    California
    what is supercool
    Jul 2002
    St Paul, Minnesota
    Heat or not, you got to get some more info. Roof top or sitting out by the side of the house it's all the same. Filter? Blower speed? Fan speed? Coil (condenser) condition, TXV or cap tube? Evap coil dirty? Air flow correct? Superheat and subcool, ambient temp, temp above the condensor, and pressure readings after the unit has been on for 15 min would all help. provide more info.
    Apr 2003
    A competent Tech?
    Jul 2005
    I'm a Super Cool Tech, what can I say ?
    Jul 2005
    Mike J , you do have a good point,
    I guess I should get off my ass and do it.
    Jul 2005
    But does'nt the 315 psi on high side indicate higher than normal operating pressure regardless of super heat/coll redaings
    Use a foaming coil cleaner on the condenser to be sure it is clean, even if the surface looks clean.
    Jul 2005
    Regarding that foam cleaner on the condenser,
    I'm worried about washing it away with many electrical lines all around, is it OK to wash it away with a hand held
    water sprayer,thatw ay I don't get too much water all around
    Apr 2003
    You might as well skimp on the coil cleaner too....
    You can either do a job professionally or hackish. It's you choice.
    Jul 2005
    jultzya
    jultzya
    I assume you are saying that I should use a source of high pressure water to clean off the coil (with cleaner of course)
    are there any alternatives to using water hoses ?
    1) a fire hose
    2)pressure washer
    3)toothbrush and a bucket of water
    4)supersoaker squrit gun
    5) spit on it
    Jul 2005
    WHAT IF I PISS ON IT ?
