Results 1 to 9 of 9
Thread: temp probe?
    Jul 2005
    I have a dial gauge, digital gauge and a expensive digital multi tester. put all three in a glass of ice water to see which one is accurate. dial guage reading is 34*, digital gauge say's 32* and multitester gauge reads 30*. which is closest to the correct temp?
    thanks to all
    txg
    well I think I can help you eliminate one of your pieces of test equipment. If you put your digital multimeter in water---you ruined it
    Jul 2005
    mac multi tester has the same wire probe as fluke.
    I didn't dunk the tester in the water just the probe.
    thats why i like fluke, they're water-proof
    If the glass is about half ice, and well mixed (keep stiring while the probe is in) it should be 32 deg: just keep the probe in the water near the bottom of the glass, not on the ice (you can use a weight like a fishing sinker to hold it down).....
    Jul 2005
    Thank you!
    txg
    Jul 2002
    St Paul, Minnesota
    If all the probes were in exactly the same spot for a period of time, they would probably read 32 but they were not and so cannot.
    That's why you stir the water.....
    SW FL
    Question Accurate
    Also Test at Room Temperature with
    Certified, CALIBRATED Gauge.
    Designer Dan
