Results 1 to 10 of 10
    Sep 2006
    Ohio
    Variable speed blowers
    Guys, I need some help here. I'm going to install a 3 ton Heat Pump and AHU system in my own house soon. I'm going to get a Carrier/Bryant/Payne system and was thinking of getting a variable speed AHU. I work on Commercial equipment and don't see a lot of Residential units, so I need your advice. Do the variable speed blowers work good or should I go with a 2 speed blower. My Service Manager told me that a lot of guys are having problems with the variable speed units and parts are much higher. He said that if the duct work is not sized just right, the blower doesn't know what speed to run at. Thanks for any advice you can give me.
    Jul 2009
    Columbia, MD
    variable speed on a ok duct system. u can set the airflow to 350cfm if your a little under. helps on humidity problems as well
    Jun 2007
    Round Rock
    The problem with variable speed blowers is that they really aren't variable speed unless you use the infinity/evolution thermostat. They are more like 2 or 3 speed blowers. There is the newer furnace which has the semi-variable speed for lack of a better term. It does the same thing as the variable speed does without the special thermostat with a normal thermostat. It still has humidity control and cost's less. The variable speed and semi-variable speed blower motors are both very expensive to replace. I haven't had to buy the newer ones yet, but have seen the price on them when replacing them under warranty. All I gotta say is "ouch" for a wholesale price.
    I like DIY'ers. They pay better to fix.
    Dec 2008
    Ontario Canada
    the ECM 2.3, and 3.0 are true variable speed motors without any special stat, they will vary frequency, and thus rpm to match a pre-programed torque amount under various firing rates, thus delivering a constant precise CFM regardless of variances in duct work.
    When the work they work great, the control modules, at least on the 2.3 models were a little sensitive to power spikes and brown outs, from what I hear the 3.0 model is a little tougher. dont know what carrier is currently using on the models you were quoted, so cant comment on them specifically, but from what I have seen, most manufactures are trending towards the Genteq line-up
    if your going variable speed, make sure you get the 10 year warranty, replacement motors are not cheap!
    A lot of people think of variable speed as meaning that they(the person) can vary the CFM.
    Sorry, thats not what it means.
    Dec 2008
    Ontario Canada
    Ah, yes, you are correct
    Jan 2002
    Ft.Worth,Tx
    Quote Originally Posted by LKJoel View Post
    I have worked on V/Drv for maybe 15 years and have only replaced maybe 3 motors on Geo-Thermal units..They are much more reliable than variable speed motors.
    'Life begins with the journey each day'
    Feb 2011
    Ontario
    Well...actually, the owner can vary the speed with the appropriate knowledge in some cases. I have a Lennox SLP98 furnace with the icomfort thermostat and have adjusted the CFM and DAT by referring to the system installer manual. This was out of necessity as I knew more about the icomfort adjustments than the HVAC installers.
    Oct 2005
    Pacific Northwest
    We should call ECM's "variable RPM" instead.
    Dec 2010
    A variable-speed blower motor is the only way to go. They are more efficient, quieter, allow you to de-humidify and are very reliable.
    If the ductwork isn't correct (which is often the case) it will try to compensate and become noisey.
    The ductwork should be checked regardless of the blower motor.
