Thread: Return
    Jul 2005
    I live in a 1500 square ft ranch home Does it matter where the cold air return is located.
    If there's only one ,it should be in a location the is "open" to most of the home,so doorways don't prevent return air from getting to it.
    If by location you high or low wall,ceiling or floor,it's not going to have much effect regardless of which one you choose.
    southern illinois
    like dash said, if one return we like to locate them in central location of home,....supply on outside perimeter and generally if supply vents in floor then return in ceiling or vice-versa to help with pulling conditioned air across living space...
    SW FL
    Exclamation C or W Return
    Originally posted by emerybean
    Does it matter where the cold air return is located?
    ALL Returns that I am aware of
    are for Warm ( Room Temp) Air ...
    Cold ( Supply ) Air is
    usually about 56 to 61'F
    or 16 to 21'F less than the room temperature.
    Designer Dan
    Jul 2005
    Naw...this guy probably lives on the North coast of Alaska and is still heating the house in July, so the return air is the cold side...
    SW FL
    Exclamation Right
    L O L
    Designer Dan
