    Jul 2002
    Alpharetta, GA
    LonMaker Version 3.1
    When I try to open the TAC Xenta 104A plug-in I get the following error message.
    ! Could not find specified entry in the database. Please check if Device Resource Files are registered properly. No values will be downloaded to database.
    I have successfully used this plug-in with this database before - but that was before I lost my hard drive and had to reload the whole ball of wax. I also get the same error with another techs computer running the same setup. I have downloaded/installed a new plug-in from TAC. BTW, I have NEVER had any plug-in issues before.
    Any ideas?
    Thanks in advance!
    Feb 2005
    Maybe Try:
    Make sure your resource file catalog is uptodate
    Sometimes the catalog gets confused if you have duplicate resource files in many locations.
    Normally all resource files should only reside in
    c:\LonWorks\Types\User\
    It is common to see some plugins not observe this rule and wierd errors happen.
    Jul 2002
    Alpharetta, GA
    I'll check it.
    Thanks 'migo!
    Pacific Time Zone
    FreezeStat - Let us know what you find out. Also I have had a few issues with plug-ins so I went through and deleted all the TAC plug-ins and reloaded the latest plug-ins and then all worked fine. Beings you are using a 104-A when you are looking at it in Vista does the 104-A go offline and then come back online quite often? All my 104-A's seem to do that and I've used hundreds of 102-AX's, about a hundred 102-ES's, and probably 50 programmable controllers on various jobs and I have no problems with them going offline like the 104-A. The 104-A works fine but it's just annoying that it goes offline and then comes back online in Vista.
    Jul 2002
    Alpharetta, GA
    I'll try deleting and re-installing the plug-ins.
    I have also had issues with the 104As going offline. We don't use them much. They seem to control well, just go offline a lot and occasionally loose their configuration.
    When I get the plug-in issue resolved, I'll post what I find out.
    Thanks Guys.
