Results 1 to 13 of 14
    Apr 2011
    tampa fl
    Fan going backwards??
    My fan is going backwards so is sucking air down and out through the sides of the outside unit. The system cools ok(ish) but this is clearly wrong and needs to be corrected. I have a nordyne /fridgidaire with a dual capacitor.and a fan with 4 wires. Probably something really simple right??
    Fairfield county Connecticuit
    Have you had a cap or motor replacement recently
    Ontario Canada
    Welcome.
    It would be best for you to call a PRo. Save you time and $ in the long run.
    Jan 2006
    Near Atlanta, GA.
    Welcome to HVAC-Talk
    But you might wanna check out the red text in the header above.
    May 2009
    Earth
    Why not take it up with the guy that replaced the fan motor? I kind of doubt the unit was shipped from the factory that way?
    Welcome
    that banner at the top needs to be made 6x larger
    Apr 2011
    Pinellas Park Florida
    capacitor is bad
    Apr 2011
    tampa fl
    I just replaced the cap, i have a red wire leaving the 'c' terminal oing to the compressor. I have a blue wire leaving the 'f' terminal and going to the fan, and i have a yellowwire and an orange wire leaving the herm terminal .
    Apr 2011
    tampa fl
    Ok I read the rules, I am a general contractor, not a DIY
    Apr 2011
    Nashville,TN
    Quote Originally Posted by jonathanteller View Post
    STOP call your local HVAC guy!!!
    Apr 2011
    fan
    Read the rules, no DIY!
    Mod Team
    Apr 2011
    tampa fl
    Thanks for your help, that's sure to fix it!
    Feb 2005
    GEORGIA
    Damn you screwed it all up......
    When ya get someone else out there, own up to what ya been dicking with........
    Bejezzes......
    "Value our Differences"
