    NAE to Graphics Alarm
    Hello,
    Not sure if this is doable or not. I'm using Advance Graphics and need to trigger a BV object that will go into alarm, when any alarm in the system goes into alarm. I can use a interlock and map every alarm object into the interlock, which would put the BV into alarm. However this would take me years.
    Is there a way to use the NAE or field controllers to trigger my BV object when it is in alarm. When I move my mouse over the NAE or field controller it does say alarm. But I've tried all kinds of different things without luck.
    Any ideas?
    Integrator,
    Is there a way I can send you a PM? I could not find a way to send you a message in your profile.
    Mar 2006
    Quote Originally Posted by integrator View Post
    Any ideas?
    Loytec
