Thread: TO: " DASH"
    hi DASH! just saw you wrote in another post the following:
    "Fridgidaire,low air flow from air handlers,if it is an air handler,the compressor was murdered!"
    we just got a new Fridgidaire Air Handler 5 ton with variable speed and just did a posting on problems....
    so this is a bad one?
    YOU are near me... maybe I will contact you I think my AC Company screwed me over. can you read my other post.... and maybe you could give me some good advice and i can call you for a quote if my outside unit indeed is bad or just to find out if i was adviced wrong. I am in Palm Harbor, Fl. and it looks like i am in need maybe of a new AC company ? (sorry my engl. not so good yet, am german)
    Thanks,
    Manuela
    Just a guess,did US Air sell/install the the air handler?
    If it's a variable speed,the air flow should be much better than the standard models ,I was refering to,can you post the model number ?
    Don't worry about your English,mines not great either.LOL
    no it wasnt US Air
    ok just came down from attick....yuck hate the thought of rats.... lol
    model number says B3BM-060k-CB
    serial# B3D050103309
    hope that helps
    outside unit is a 4 ton American Standard do u need model number there too?
    Thanks so much
    manuela
    [Edited by jamierenae on 07-25-2005 at 11:01 PM]
    I'll try to look it up Tuesday,hopefully someone will post the specifications before then.
    ok thanks so much i appreciate this.
    The spec sheets I have ,very limited,show that as a standard PSC motor not a variable speed.That doesn't mean that's the problem,I post more on your other thread.
